Eclipse Community ForumsHow to give security option in BIRT reporting tool
https://www.eclipse.org/forums/index.php/mv/msg/210257/674526/#msg_674526
Could you plz help me regarding the below
I have built some reports in BIRT reporting,i just want to restrict to access those reports to selected users only but i'm unable to do that(i want to give selected users to view the reports based on the users) so plz help on that how to restrict the user to view the reports that means how to implement it on BIRT reporting tool.
plz give an idea about this, Is it implement in BIRT using JAVA coding then plz send the details
waiting for the replies.
Thanks in advance.
Parasuram. ]]>parasu 2011-05-27T09:02:04-00:00Re: How to give security option in BIRT reporting tool
https://www.eclipse.org/forums/index.php/mv/msg/210257/675335/#msg_675335
I think this can be done only in commercial version of birt. In our small company (approx 60 employees) we have deployed three separated instances of birt - public, restricted and secured. Access to those versions is controlled through ldap groups.
Tomas]]>Tomas Greif2011-05-31T08:10:45-00:00Re: How to give security option in BIRT reporting tool
https://www.eclipse.org/forums/index.php/mv/msg/210257/677080/#msg_677080
can you please confirm that we need commercial version if we want group access restrictions, and is there a workaround to this lack of functionality?
Tomas, what do you mean by saying "we have deployed three separated instances of birt - public, restricted and secured."
Does it mean three different Tomcat servers with three sets of same reports or something else? We are using Windows AD, can you or anybody else, let me know what is needed in order to make it work in our environment?
We have quite different groups of users, so reports are not overlaping. I know this is not really flexible solution, however it is easy to setup and works fine in our environment.
Tomas
]]>Tomas Greif2011-06-07T18:21:10-00:00Re: How to give security option in BIRT reporting tool
https://www.eclipse.org/forums/index.php/mv/msg/210257/677225/#msg_677225
nlajka -2011-06-07T21:10:14-00:00
