Eclipse Community ForumsDisabling Eclipse plugins upon startup programmatically
https://www.eclipse.org/forums/index.php/mv/msg/210006/673256/#msg_673256
The idea is to make those plugins inactive based on some criteria. We need to do this very early so that any perspective or views from this plugin do not show up in Open Perspective or Show Views dialog.
Any idea on how to do this? Thanks,
- Raja.]]>Raja Kannappan2011-05-23T03:26:18-00:00Re: Disabling Eclipse plugins upon startup programmatically
https://www.eclipse.org/forums/index.php/mv/msg/210006/673690/#msg_673690
If there are plugin.xml contributions, you need to uninstall to make them disappear.
PW
]]>Paul Webster2011-05-24T13:33:28-00:00Re: Disabling Eclipse plugins upon startup programmatically
https://www.eclipse.org/forums/index.php/mv/msg/210006/674077/#msg_674077
How do I uninstall contributions from plugin.xml? Can you explain or point me to relevant sources? Thanks.
]]>Raja Kannappan2011-05-25T18:13:28-00:00Re: Disabling Eclipse plugins upon startup programmatically
https://www.eclipse.org/forums/index.php/mv/msg/210006/674303/#msg_674303
See http://www.ibm.com/developerworks/library/os-eclipse-bundlemgmt/index.html which talks about the bundle lifecycle, installing, starting, stoping, and uninstalling bundles.
PW
]]>Paul Webster2011-05-26T13:11:45-00:00Re: Disabling Eclipse plugins upon startup programmatically
https://www.eclipse.org/forums/index.php/mv/msg/210006/675630/#msg_675630
Raja Kannappan2011-06-01T04:12:56-00:00
