Eclipse Community ForumsTrimming dynamic web projects
https://www.eclipse.org/forums/index.php/mv/msg/208393/667602/#msg_667602
v xyz
> JAX-WS Web Services
> Deployment Descriptor: xyz
> Java Resources: src
> JavaScript Resources
> Web Resources: WebContent
> build
> WebContent
If I'm not consuming JavaScript or JAX-WS, I may not want the added mess
of having these two around.
(Yes, I realize that if I switch to Package Explorer, things get quieter.)
What's the theory or best practice here?]]>Russell Bateman2011-04-29T20:52:59-00:00Re: Trimming dynamic web projects
https://www.eclipse.org/forums/index.php/mv/msg/208393/668271/#msg_668271
Customize View...). We've tried to make JavaScript Resources as non-intrusive as possible in Helios, but you're free to disable anything and everything you don't care about.]]>Nitin Dahyabhai2011-05-04T18:35:33-00:00Re: Trimming dynamic web projects
https://www.eclipse.org/forums/index.php/mv/msg/208393/668274/#msg_668274
> By default you're seeing the Project Explorer, which is meant to combine
> the functionalities of many of the other Explorerish views. I'm not sure
> what you mean by "best practice", but any types of Content you don't
> want included can be disabled from the in-view preferences
> ( http://help.eclipse.org/helios/topic/org.eclipse.platform.do c.user/tasks/tasks-48b.htm).
> care about.
Wow. This is perfect--does everything I ever wanted to do.
