Quote: |
I could not install connectors after installing plug-in from the Helios repository. What should I do? There was an issue with update sites layout for "release" versions, meaning that a different releases had references to the same connectors update site location. So, we have decided to correct this issue, so that there will be no problems with the future releases. Unfortunately there is no way to fix the Helios repository at this stage and the right way to avoid the issue is to install the latest plug-in version from the "Early access" update site. It is not the realease but development build, but it still stable and better because it contains a lot of fixes for a different issues. |
