Eclipse Community Forumsorg.eclipse.papyrus.tabbedproperties.comments.propertysection
https://www.eclipse.org/forums/index.php/mv/msg/198883/634329/#msg_634329
I was looking in code of Papyrus from there svn I found a plug-in " org.eclipse.papyrus.tabbedproperties.comments.propertysectio n " it is implementing a class "CommentPropertySection.java"
in this class they are using "richText = CommentRichTextFormToolkit.createFocusAwareRichTextEditor(ge tWidgetFactory(), parent, "", comment, SWT.NONE, EditorUtils.getMultiDiagramEditor().getEditorSite());"
which is using instance of some other editor called "CoreMultiDiagramEditor" by using an interface "IMultiDiagramEditor".
I have a question regarding this plugin.
if I am a Papyrus user how can I see functionality of this plugin in Papyrus?
/Jaguar ]]>Dani2010-10-21T09:54:18-00:00Re: org.eclipse.papyrus.tabbedproperties.comments.propertysection
https://www.eclipse.org/forums/index.php/mv/msg/198883/634362/#msg_634362
currently in papyrus, you can not see the usage of this plugin, as this is win32 dependant, and we aimed to provide Papyrus without restriction such as: use Windows only.
You can see some section examples, in the plugin org.eclipse.papyrus.profile. This plugin is available by default in the Papyrus installation.
Rémi]]>Remi Schnekenburger2010-10-21T12:17:47-00:00Re: org.eclipse.papyrus.tabbedproperties.comments.propertysection
https://www.eclipse.org/forums/index.php/mv/msg/198883/634385/#msg_634385
Sorry to bother you again and again. Actually I am stuck and unable to get any idea. For now I wanted to ask you about xtext editors used in papyrus. These are three xtext editor plugins used to define grammer etc for properties.
I have seen all of these three plugins but could not find how you are using it when you drag property in a class then click it and get a text area to write. it gives code completion and code highligting. I wanted to know where can I find this implementation? is it implemented in some other plugin? please help me otherwise I am stucked .
