Eclipse Community ForumsRemote service registration using OSGi Blueprint
https://www.eclipse.org/forums/index.php/mv/msg/196164/625201/#msg_625201
I have been looking for some example/samples to register remove services
using OSGi blueprint. The Hello sample does this through Activator and
it uses ECF specific artifacts. Below is the sample service registration
and this works in CXF.
Reason I am asking this question is that the hello example says, I need
to create the ECF container which may not be possible or desirable when
registering services dynamically.
