Eclipse Community ForumsEMF XMI Serialization
https://www.eclipse.org/forums/index.php/mv/msg/195479/622871/#msg_622871
can somebody explain me how I can create a XMI root element in my code to put all elements under this root element.
Thanks in advance!
Here is the sample code:
public class SerializationUtility {
public void serialize() throws IOException {
ResourceSet rs = new ResourceSetImpl();
XMIResourceImpl myXMResourceImpl = new XMIResourceImpl();
myXMResourceImpl.getDefaultSaveOptions().put( XMIResource.OPTION_KEEP_DEFAULT_CONTENT, Boolean.TRUE);
// Register the base XML resource factory implementation in the local resource factory registry.
rs.getResourceFactoryRegistry().getExtensionToFactoryMap().p ut( "xmi", new XMIResourceFactoryImpl());
URI fileURI = URI.createFileURI( "ResourcesFZI.xmi");
Resource resource = rs.createResource( fileURI);
// add the root objects to the resource
Iterator<ComputerResources> itr = ComputerCollectionGenerator.computerResoucres.iterator();
while ( itr.hasNext()) {
ComputerResources next = itr.next();
resource.getContents().add( next);
resource.save( null);
}]]>Ugur Kocak2010-05-11T08:36:54-00:00Re: EMF XMI Serialization
https://www.eclipse.org/forums/index.php/mv/msg/195479/622878/#msg_622878
If the resource's contents contain multiple elements, there will be an
XMI root element to hold them all. Otherwise, the one element in the
contents will be used as the root.
Ugur Kocak wrote:
> Thanks in advance!
>]]>Ed Merks2010-05-11T11:17:42-00:00
