Eclipse Community ForumsProblem with associations between classes of different diagrams/packages
https://www.eclipse.org/forums/index.php/mv/msg/194411/618648/#msg_618648
Originally posted by: markus.heintz.iese.fhg.de
I got a UML2 Model that is distributed/spread over several diagrams/files.
Classes from one diagram have associations to classes of another diagram
(Packages).
I can not manage to show the associations between these classes in all
concerning diagrams.
Here is an example of what I'm trying to do:
Diagram D1 has the classes A
Diagram D2 has the classes X
An Assosiation a1 should connect class A and X ( A -----a1----> X),
To add the association a1 in Diagram D1 I created a shortcut of the
class X (X-shortcut) in diagram D1.
=> D1 = { A, X-shortcut }
Now I created the assosiation that connects class A and X
=> D1 = { A, X-shortcut, --a1--> }
Then I created in Diagram D2 a shortcut of class A (A-shortcut)
=> D2 = {X, A-shortcut}
How can I make association a1 appear in diagram D2?
Is this possible?
Thanks a lot for the help!
Markus]]>2008-03-27T17:13:39-00:00
