Eclipse Community ForumsEclipse plugin - can't get it to work
https://www.eclipse.org/forums/index.php/mv/msg/1893/5406/#msg_5406
Originally posted by: x.x.com
Downloaded eclipse 3.20 - clean install - and pointed it at the eclipse
plugin update :
Started new project then do 'New BPEL process file'.
Filled in the process name and the namespace. Clicked finish and, very
briefly
the message 'creating process from template' flashes in the dialogue but the
dialogue
does not close and the bpel is never created.
The only way to get rid of the dialogue is to click cancel. Can anyone
help?
P.S. I have tried both 3.20 final release and 3.20 RC7. Same behaviour in
both.]]>2006-08-08T22:46:04-00:00Re: Eclipse plugin - can't get it to work
https://www.eclipse.org/forums/index.php/mv/msg/1893/5438/#msg_5438
> plugin update :
> http://download.eclipse.org/technology/bpel/update-site/
> Plugin installed. Restarted eclipse.
> briefly
> dialogue
> help?
> both.
Is there a message in the .metadata/.log file? Could you open a bug in
bugzilla with this information? Thanks.
Michal: have you seen this problem?
james]]>James Moody2006-08-14T15:47:30-00:00Re: Eclipse plugin - can't get it to work
https://www.eclipse.org/forums/index.php/mv/msg/1893/5450/#msg_5450
!ENTRY org.eclipse.bpel.ui 4 0 2006-08-15 14:30:00.000
!MESSAGE <no message>
!STACK 0
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:381)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 851)
at org.eclipse.bpel.ui.wizards.NewFileWizard.performFinish(Unkn own Source)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:355)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:660)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
at org.eclipse.bpel.ui.wizards.BPELCreateOperation.save(Unknown Source)
at org.eclipse.bpel.ui.wizards.BPELCreateOperation.run(Unknown Source)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
... 40 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at org.eclipse.core.launcher.Main.main(Main.java:952)]]>2006-08-15T13:31:36-00:00Re: Eclipse plugin - can't get it to work
https://www.eclipse.org/forums/index.php/mv/msg/1893/5455/#msg_5455
P.S. I am using Java 1.5.0_06]]>2006-08-15T13:47:19-00:00Re: Eclipse plugin - can't get it to work
https://www.eclipse.org/forums/index.php/mv/msg/1893/5494/#msg_5494
Originally posted by: dshookowsky.example.org
I had this issue as well. I'm not too familiar with eclipse having
installed it only to check out the BPEL designer, but I found that making
sure that I had a project open and that the default window (with the
graphic background) was closed.]]>2006-08-17T15:05:39-00:00Re: Eclipse plugin - can't get it to work
https://www.eclipse.org/forums/index.php/mv/msg/1893/5506/#msg_5506
I do have a project open and selected and I still get this error every
single time.
Can anyone help?
"Dan Shookowsky" <dshookowsky@example.org> wrote in message
news:8b59ed62027aa9a42de228d14843844b$1@www.eclipse.org...
>]]>2006-08-18T13:10:28-00:00Re: Eclipse plugin - can't get it to work
https://www.eclipse.org/forums/index.php/mv/msg/1893/5668/#msg_5668
Does nobody have any ideas on this?]]>2006-08-25T13:06:15-00:00Re: Eclipse plugin - can't get it to work
https://www.eclipse.org/forums/index.php/mv/msg/1893/5777/#msg_5777
Originally posted by: gert.anova.be
Jason,
I had the same problem. It appears that you can create a file with the
extension .bpel in your workspace and double-click on it to get the
editor to open. It's a bit of a work-around, but at least you can get
started...
