Eclipse Community Forumserror updating Ganymede to Galileo
https://www.eclipse.org/forums/index.php/mv/msg/178783/567811/#msg_567811
I'm trying to update eclipse Ganymede to Galileo.
I added http://download.eclipse.org/releases/galileo to the update sites.
Eclipse recognizes the updates and tries to dl/install them but
encounters the following error:
An error occurred while collecting items to be installed
No repository found containing: com.ibm.icu/osgi.bundle/4.0.1.v20090415
com.jcraft.jsch/osgi.bundle/0.1.41.v200903070017
No repository found containing: javax.xml/osgi.bundle/1.3.4.v200902170245
org.apache.ant/osgi.bundle/1.7.1.v20090120-1145
org.apache.jasper/osgi.bundle/5.5.17.v200903231320
org.apache.xerces/osgi.bundle/2.9.0.v200909240008
org.apache.xml.resolver/osgi.bundle/1.2.0.v200902170519
org.apache.xml.serializer/osgi.bundle/2.7.1.v200902170519
org.eclipse.ant.core/osgi.bundle/3.2.100.v20090520
org.eclipse.ant.ui/osgi.bundle/3.4.0.v20090520
Error closing the output stream for
org.eclipse.cdt.gnu.build/org.eclipse.update.feature/6.0.0.2 00906161748
on repository file:/scream/home/farbea2/tools/eclipse/.
Error unzipping
/tmp/org.eclipse.cdt.gnu.build_6.0.0.20090616174813150227528 71639845.jar:
Invalid zip file format
org.eclipse.compare/osgi.bundle/3.5.0.I20090514-0808
org.eclipse.core.commands/osgi.bundle/3.5.0.I20090525-2000
org.eclipse.core.contenttype/osgi.bundle/3.4.0.v20090429-180 0
org.eclipse.core.databinding/osgi.bundle/1.2.0.I20090604-200 0
org.eclipse.core.databinding.beans/osgi.bundle/1.2.0.I200905 25-2000
org.eclipse.core.expressions/osgi.bundle/3.4.100.v20090429-1 800
org.eclipse.core.filebuffers/osgi.bundle/3.5.0.v20090526-200 0
org.eclipse.core.filesystem/osgi.bundle/1.2.0.v20090507
org.eclipse.core.jobs/osgi.bundle/3.4.100.v20090429-1800
org.eclipse.core.net/osgi.bundle/1.2.0.I20090522-1010
org.eclipse.core.net.linux.x86/osgi.bundle/1.1.0.I20081021
org.eclipse.core.resources/osgi.bundle/3.5.0.v20090512
org.eclipse.core.resources.compatibility/osgi.bundle/3.4.0.v 20090505
org.eclipse.core.runtime/osgi.bundle/3.5.0.v20090525
org.eclipse.core.runtime.compatibility/osgi.bundle/3.2.0.v20 090413
org.eclipse.core.runtime.compatibility.auth/osgi.bundle/3.2. 100.v20090413
org.eclipse.core.runtime.compatibility.registry/osgi.bundle/ 3.2.200.v20090429-1800
org.eclipse.core.variables/osgi.bundle/3.2.200.v20090521
org.eclipse.cvs/osgi.bundle/1.0.300.v200906051444
org.eclipse.debug.core/osgi.bundle/3.5.0.v20090526-1600
org.eclipse.debug.ui/osgi.bundle/3.5.0.v20090603
org.eclipse.draw2d/osgi.bundle/3.5.0.v20090528-1511
org.eclipse.ecf/osgi.bundle/3.0.0.v20090604-1131
org.eclipse.ecf.filetransfer/osgi.bundle/3.0.0.v20090604-113 1
org.eclipse.ecf.identity/osgi.bundle/3.0.0.v20090604-1131
org.eclipse.ecf.provider.filetransfer/osgi.bundle/3.0.0.v200 90604-1131
org.eclipse.ecf.provider.filetransfer.ssl/osgi.bundle/1.0.0. v20090604-1131
org.eclipse.ecf.ssl/osgi.bundle/1.0.0.v20090604-1131
org.eclipse.emf.common/osgi.bundle/2.5.0.v200906080927
org.eclipse.emf.common.ui/osgi.bundle/2.5.0.v200906080927
No ruinox.p2.ui.sdk/osgi.bundle/1.0.100.v20090520-1905
org.eclipse.equinox.p2.updatechecker/osgi.bundle/1.1.0.v2009 0520-1905
org.eclipse.equinox.p2.updatesite/osgi.bundle/1.0.100.v20090 525
org.eclipse.equinox.preferences/osgi.bundle/3.2.300.v2009052 0-1800
org.eclipse.equinox.registry/osgi.bundle/3.4.100.v20090520-1 800
org.eclipse.equinox.security/osgi.bundle/1.0.100.v20090520-1 800
org.eclipse.equinox.security.ui/osgi.bundle/1.0.100.v2009052 0-1800
org.eclipse.equinox.simpleconfigurator/osgi.bundle/1.0.100.v 20090520-1905
org.eclipse.equinox.simpleconfigurator.manipulator/osgi.bund le/1.0.100.v20090520-1905
org.eclipse.gef/osgi.bundle/3.5.0.v20090528-1511
org.eclipse.help/osgi.bundle/3.4.0.v20090526
org.eclipse.help.appserver/osgi.bundle/3.1.400.v20090429_180 0
org.eclipse.help.base/osgi.bundle/3.4.0.v200906051444
org.eclipse.help.ui/osgi.bundle/3.4.0.v20090528
org.eclipse.help.webapp/osgi.bundle/3.4.0.v20090429_1800
org.eclipse.jdt/osgi.bundle/3.5.0.v200906051444
org.eclipse.jdt.apt.core/osgi.bundle/3.3.200.v20090528-1135
org.eclipse.jdt.apt.pluggable.core/osgi.bundle/1.0.200.v2009 0526-2130
org.eclipse.jdt.apt.ui/osgi.bundle/3.3.200.v20090528-1135
org.eclipse.jdt.compiler.apt/osgi.bundle/1.0.200.v20090528-1 135
org.eclipse.jdt.compiler.tool/osgi.bundle/1.0.100.v_963
org.eclipse.jdt.core/osgi.bundle/3.5.0.v_963
org.eclipse.jdt.core.manipulation/osgi.bundle/1.3.0.v2009060 3
org.eclipse.jdt.debug/osgi.bundle/3.5.0.v20090526
org.eclipse.jdt.debug.ui/osgi.bundle/3.4.0.v20090527
org.eclipse.jdt.doc.user/osgi.bundle/3.5.0.v20090603-1530
org.eclipse.jdt.junit/osgi.bundle/3.5.0.v20090526-2000
org.eclipse.jdt.junit.runtime/osgi.bundle/3.4.100.v20090513- 2000
org.eclipse.jdt.junit4.runtime/osgi.bundle/1.1.0.v20090513-2 000
org.eclipse.jdt.launching/osgi.bundle/3.5.0.v20090527
org.eclipse.jdt.ui/osgi.bundle/3.5.0.v20090604
org.eclipse.jem.util/osgi.bundle/2.0.200.v200905140200
org.eclipse.jface/osgi.bundle/3.5.0.I20090525-2000
org.eclipse.jface.databinding/osgi.bundle/1.3.0.I20090525-20 00
org.eclipse.jface.text/osgi.bundle/3.5.0.v20090602
org.eclipse.jsch.core/osgi.bundle/1.1.100.I20090430-0408
org.eclipse.jsch.ui/osgi.bundle/1.1.200.I20090430-0408
org.eclipse.ltk.core.refactoring/osgi.bundle/3.5.0.v20090513 -2000
org.eclipse.ltk.ui.refactoring/osgi.bundle/3.4.100.v20090604
org.eclipse.osgi/osgi.bundle/3.5.0.v20090520
org.eclipse.osgi.services/osgi.bundle/3.2.0.v20090520-1800
org.eclipse.osgi.util/osgi.bundle/3.2.0.v20090520-1800
org.eclipse.platform/osgi.bundle/3.3.200.v200906051444
org.eclipse.platform.doc.user/osgi.bundle/3.5.0.v20090604-20 00
org.eclipse.rcp/osgi.bundle/3.5.0.v200906051444
org.eclipse.search/osgi.bundle/3.5.0.v20090526-2000
No repository found containing: org.eclipse.swt/osgi.bundle/3.5.0.v3550a
org.eclipse.swt.gtk.linux.x86/osgi.bundle/3.5.0.v3550a
org.eclipse.team.core/osgi.bundle/3.5.0.I20090527-0620
org.eclipse.team.cvs.core/osgi.bundle/3.3.200.I20090430-0408
org.eclipse.team.cvs.ssh2/osgi.bundle/3.2.200.I20090508-2000
org.eclipse.team.cvs.ui/osgi.bundle/3.3.200.I20090521-1750
org.eclipse.team.ui/osgi.bundle/3.5.0.I20090430-0408
org.eclipse.text/osgi.bundle/3.5.0.v20090513-2000
org.eclipse.ui/osgi.bundle/3.5.0.I20090604-2000
org.eclipse.ui.browser/osgi.bundle/3.2.300.v20090526
org.eclipse.ui.cheatsheets/osgi.bundle/3.3.200.v20090526
org.eclipse.ui.console/osgi.bundle/3.4.0.v20090513
org.eclipse.ui.editors/osgi.bundle/3.5.0.v20090527-2000
org.eclipse.ui.externaltools/osgi.bundle/3.2.0.v20090504
org.eclipse.ui.forms/osgi.bundle/3.4.0.v20090526
org.eclipse.ui.ide/osgi.bundle/3.5.0.I20090525-2000
org.eclipse.ui.ide.application/osgi.bundle/1.0.100.I20090525 -2000
org.eclipse.ui.intro/osgi.bundle/3.3.0.v20090526
org.eclipse.ui.intro.universal/osgi.bundle/3.2.300.v20090526
org.eclipse.ui.navigator/osgi.bundle/3.4.0.I20090525-2000
org.eclipse.ui.navigator.resources/osgi.bundle/3.4.0.I200905 25-2000
org.eclipse.ui.net/osgi.bundle/1.2.0.I20090430-0408
org.eclipse.ui.presentations.r21/osgi.bundle/3.2.100.I200810 07-0800
org.eclipse.ui.views/osgi.bundle/3.4.0.I20090525-2000
org.eclipse.ui.views.log/osgi.bundle/1.0.100.v20090527
org.eclipse.ui.views.properties.tabbed/osgi.bundle/3.5.0.I20 090429-1800
org.eclipse.ui.workbench/osgi.bundle/3.5.0.I20090603-2000
org.eclipse.ui.workbench.compatibility/osgi.bundle/3.2.0.I20 090429-1800
org.eclipse.ui.workbench.texteditor/osgi.bundle/3.5.0.v20090 603
org.eclipse.update.configurator/osgi.bundle/3.3.0.v20090312
org.eclipse.update.core/osgi.bundle/3.2.300.v20090525
org.eclipse.update.core.linux/osgi.bundle/3.2.100.v20081008
org.eclipse.update.scheduler/osgi.bundle/3.2.200.v20081127
org.eclipse.update.ui/osgi.bundle/3.2.200.v20090213
org.eclipse.wst.common.emf/osgi.bundle/1.1.300.v200905060430
org.eclipse.wst.common.emfworkbench.integration/osgi.bundle/ 1.1.300.v200811200330
org.eclipse.wst.common.frameworks/osgi.bundle/1.1.300.v20090 4160730
org.eclipse.wst.common.frameworks.ui/osgi.bundle/1.1.300.v20 0904160730
org.eclipse.wst.common.modulecore/osgi.bundle/1.1.300.v20090 4132230
org.eclipse.wst.common.project.facet.core/osgi.bundle/1.4.0. v200906080535
org.eclipse.wst.common.snippets/osgi.bundle/1.1.300.v2009031 20643
org.eclipse.wst.common.ui/osgi.bundle/1.1.402.v200901262305
org.eclipse.wst.common_core.feature/org.eclipse.update.featu re/3.1.0.v200903021835-7B77FXTF7RZHITIwQkLs_V
org.eclipse.wst.common_ui.feature/org.eclipse.update.feature /3.1.0.v200903021835-7B5FREDhdMNPm7dkmBmpUJxRlMta
org.eclipse.wst.dtd.core/osgi.bundle/1.1.300.v200904181727
org.eclipse.wst.dtd.ui/osgi.bundle/1.0.400.v200904300717
org.eclipse.wst.dtdeditor.doc.user/osgi.bundle/1.0.500.v2009 04292308
org.eclipse.wst.sse.core/osgi.bundle/1.1.400.v200905141750
org.eclipse.wst.sse.ui/osgi.bundle/1.1.100.v200905141750
org.eclipse.wst.standard.schemas/osgi.bundle/1.0.200.v200902 270215
org.eclipse.wst.validation/osgi.bundle/1.2.102.v200905201610
org.eclipse.wst.validation.ui/osgi.bundle/1.2.104.v200904232 035
org.eclipse.wst.xml.core/osgi.bundle/1.1.400.v200904300540
org.eclipse.wst.xml.ui/osgi.bundle/1.1.0.v200905242047
org.eclipse.wst.xml_core.feature/org.eclipse.update.feature/ 3.1.0.v200901260254-7C7OFPeF7RZHIXHnTz0Jqc0
org.eclipse.wst.xml_ui.feature/org.eclipse.update.feature/3. 1.0.v200905240756-7H6FMVDxtkM-5OgPGKK4xQocS5AL
org.eclipse.wst.xml_userdoc.feature/org.eclipse.update.featu re/3.1.1.v200906020459-50FR7AkF77f7MESDKEF
org.eclipse.wst.xmleditor.doc.user/osgi.bundle/1.0.600.v2009 01231300
org.eclipse.wst.xsd.core/osgi.bundle/1.1.401.v200903020335
org.eclipse.wst.xsd.ui/osgi.bundle/1.2.203.v200904300717
org.eclipse.wst.xsdeditor.doc.user/osgi.bundle/1.0.700.v2009 05182240
org.eclipse.xsd/osgi.bundle/2.5.0.v200906080927
org.eclipse.xsd.edit/osgi.bundle/2.5.0.v200906080927
org.junit/osgi.bundle/3.8.2.v20090203-1005
No repository found containing: org.junit4/osgi.bundle/4.5.0.v20090423
org.sat4j.core/osgi.bundle/2.1.0.v20090520
No repository found containing: org.sat4j.pb/osgi.bundle/2.1.0.v20090520
org.eclipse.compare.core/osgi.bundle/3.5.0.I20090430-0408
org.eclipse.core.databinding.observable/osgi.bundle/1.2.0.I2 0090604-2000
org.eclipse.core.databinding.property/osgi.bundle/1.2.0.I200 90526-2000
org.eclipse.cvs/org.eclipse.update.feature/1.1.100.v20090514 -7E79FEc9BJ99r9YEV6IOIF
org.eclipse.cvs_root/binary/1.1.100.v20090514-7E79FEc9BJ99r9 YEV6IOIF
org.eclipse.ecf.provider.filetransfer.httpclient/osgi.bundle /3.0.0.v20090604-1131
org.eclipse.ecf.provider.filetransfer.httpclient.ssl/osgi.bu ndle/1.0.0.v20090604-1131
org.eclipse.equinox.concurrent/osgi.bundle/1.0.0.v20090520-1 800
org.eclipse.equinox.ds/osgi.bundle/1.1.0.v20090601
org.eclipse.equinox.p2.publisher/osgi.bundle/1.0.0.v20090527 -1812
org.eclipse.equinox.p2.repository/osgi.bundle/1.0.0.v2009060 1-1921
org.eclipse.equinox.p2.repository.tools/osgi.bundle/1.0.0.v2 0090527-1812
org.eclipse.equinox.p2.ui.sdk.scheduler/osgi.bundle/1.0.0.v2 0090520-1905
org.eclipse.equinox.p2.user.ui/org.eclipse.update.feature/1. 1.0.v20090605-1440-7u6Fb3FbPbJP5MiKiZgpdl
org.eclipse.equinox.util/osgi.bundle/1.0.100.v20090520-1800
org.eclipse.help/org.eclipse.update.feature/1.1.0.v20090602- 7e7eFAlFEx2XZoYqvM67e6F
org.eclipse.jdt/org.eclipse.update.feature/3.5.0.v20090527-2 000-7r88FEeFJePyvYeA27DiZdc1
org.eclipse.jdt_root/binary/3.5.0.v20090527-2000-7r88FEeFJeP yvYeA27DiZdc1
org.eclipse.platform/org.eclipse.update.feature/3.5.0.v20090 605-9gEeG1HFtQcmRThO2V4dTfhVTK1JW1-J
org.eclipse.platform_root/binary/3.5.0.v20090605-9gEeG1HFtQc mRThO2V4dTfhVTK1JW1-J
org.eclipse.rcp.configuration_root.gtk.linux.x86/binary/1.0. 0.I20090605-1444
org.eclipse.rcp/org.eclipse.update.feature/3.5.0.v20090519-9 SA0FwxFv6x089BEe3TVh51
org.eclipse.rcp_root/binary/3.5.0.v20090519-9SA0FwxFv6x089BE e3TVh51
org.eclipse.team.cvs.ssh/osgi.bundle/3.2.100.I20090508-2000
org.hamcrest.core/osgi.bundle/1.1.0.v20090501071000
org.mortbay.jetty.server/osgi.bundle/6.1.15.v200905151201
org.mortbay.jetty.util/osgi.bundle/6.1.15.v200905182336]]>Alex Farberov2009-06-24T16:08:52-00:00
