Eclipse Community ForumsOdd bug in generated graphical editor
https://www.eclipse.org/forums/index.php/mv/msg/177826/565192/#msg_565192
------=_NextPart_000_0011_01C98D03.323719E0
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=original
I generated a simple editor from the attached .emf file. Oddly, when
running the generated graphical editor, one can nicely draw nodes and
connections. But whenever one creates a new node, then suddenly all
connections drawn so far are removed again from the diagram.
Can others reproduce this? Any idea why? Can one fix this somehow? And
is this now an Epsilon/Eugenia bug or a genuine GMF bug? I presume the
latter, but just wanted to double check. Before reporting transferring
this to the GMF NG.
