Eclipse Community ForumsPagebreak within dynamic text
https://www.eclipse.org/forums/index.php/mv/msg/175529/559233/#msg_559233
I want to display a quite long text (about 1.5 pages) in a dynamic text-element
The problem is, that birt does a pagebreak before the text, so there is a lot of free space on the first page.
What can I do to remove this pagebreak?
Configuration:
BIRT-version 2.5.2
PDF-Output
seperate run and render task
Peter]]>No real name2010-09-16T06:50:25-00:00Re: Pagebreak within dynamic text
https://www.eclipse.org/forums/index.php/mv/msg/175529/559454/#msg_559454
Are you using fixed or auto layout? Look at the general properties for
the report. Is the text from a db? If not can you post the report?
Jason
On 9/16/2010 2:50 AM, peter@pilgerstorfer.at wrote:
> text-element
> Configuration:
> BIRT-version 2.5.2
> PDF-Output
> Peter]]>Jason Weathersby2010-09-16T16:58:47-00:00Re: Pagebreak within dynamic text
https://www.eclipse.org/forums/index.php/mv/msg/175529/559543/#msg_559543
In my report the text comes from the db.
Peter
Here is a small example report:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<property name="units">cm</property>
<property name="iconFile">/templates/simple_listing.gif</property>
<property name="cheatSheet"> org.eclipse.birt.report.designer.ui.cheatsheet.simplelisting </property>
<property name="layoutPreference">fixed layout</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="27">
<text-property name="displayName"></text-property>
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Data Set" id="28">
<list-property name="columnHints">
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTNAME</property>
<text-property name="displayName">PRODUCTNAME</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTNAME</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">PRODUCTNAME</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select CLASSICMODELS.PRODUCTS.PRODUCTCODE,
CLASSICMODELS.PRODUCTS.PRODUCTNAME
from CLASSICMODELS.PRODUCTS]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:formattingHints>
<design:displaySize>15</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTNAME</design:name>
<design:position>2</design:position>
<design:precision>70</design:precision>
<design:uiHints>
<design:displayName>PRODUCTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTNAME</design:label>
<design:displaySize>70</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="24">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="25">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="26">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="29">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression" type="javascript">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["PRODUCTNAME"]</expression >
</structure>
</list-property>
<column id="43"/>
<column id="44"/>
<detail>
<row id="35">
<cell id="36">
<data id="37">
<property name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="38">
<data id="39">
<property name="resultSetColumn">PRODUCTNAME</property>
</data>
</cell>
</row>
<row id="45">
<cell id="46">
<property name="colSpan">2</property>
<property name="rowSpan">1</property>
<text id="48">
<property name="contentType">auto</property>
<text-property name="content"><![CDATA[a very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very
very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very
very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very very long text]]></text-property>
</text>
</cell>
</row>
</detail>
<footer>
<row id="40">
<cell id="41"/>
<cell id="42"/>
</row>
</footer>
</table>
</body>
</report>
]]>No real name2010-09-17T06:22:59-00:00Re: Pagebreak within dynamic text
https://www.eclipse.org/forums/index.php/mv/msg/175529/559652/#msg_559652
This issue has been fixed in 2.6. You can set the row height on the row
that has the large text element and it will work in 2.6. I am attaching
the modified example.
Jason
id="1">
2.6.0.v20100531 Build <2.6.0.v20100609-1613></property>
<property
<data-sources>
<oda-data-source
id="27">
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="29">
<property name="height">10in</property>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<column id="43"/>
<column id="44"/>
<detail>
<row id="35">
<cell id="36">
<data id="37">
<property
</data>
</cell>
<cell id="38">
<data id="39">
<property
</data>
</cell>
</row>
<row id="45">
<property name="height">9in</property>
<cell id="46">
<text id="48">
</text>
</cell>
</row>
</detail>
<footer>
<row id="40">
<cell id="41"/>
<cell id="42"/>
</row>
</footer>
</table>
</body>
</report>
On 9/17/2010 2:23 AM, peter@pilgerstorfer.at wrote:
> I tried with auto layout, but it still doesn't work.
> Peter
> id="1">
> <data-sources>
> <property
> </property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:criteria/>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="29">
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="43"/>
> <column id="44"/>
> <detail>
> <row id="35">
> <cell id="36">
> <data id="37">
> </data>
> </cell>
> <cell id="38">
> <data id="39">
> </data>
> </cell>
> </row>
> <row id="45">
> <cell id="46">
> <text id="48">
> very very
> </text>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="40">
> <cell id="41"/>
> <cell id="42"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
>]]>Jason Weathersby2010-09-17T13:48:39-00:00Re: Pagebreak within dynamic text
https://www.eclipse.org/forums/index.php/mv/msg/175529/559861/#msg_559861
I have now upgraded to Birt 2.6.0 and tried your report.
In your example only the top 9in of the text are shown. I need to display the whole text.
Peter]]>No real name2010-09-20T07:30:06-00:00Re: Pagebreak within dynamic text
https://www.eclipse.org/forums/index.php/mv/msg/175529/559884/#msg_559884
I set the page-break-inside property of the detail-row from aviod (standard in 2.6?) to auto
however, it doesn't work with an html-formatted textfield
