Eclipse Community ForumsMissing requirement org.eclipse.cor.runtime
https://www.eclipse.org/forums/index.php/mv/msg/172851/550024/#msg_550024
i am trying to install Black Berry web pluggin in Eclipse Helios
but i am getting the following error of missing dependencies:
Cannot complete the install because one or more required items could not be found.
Software being installed: BlackBerry Web Development Plug-in 1.0.0.200907241249-33 (net.rim.browser.tools.feature.feature.group 1.0.0.200907241249-33)
Missing requirement: BlackBerry Web Development Plug-in 1.0.0.200907241249-33 (net.rim.browser.tools.feature.feature.group 1.0.0.200907241249-33) requires 'org.eclipse.core.runtime [3.4.0,3.5.0)' but it could not be found
can anyone help
Thanks in advance,
Nitesh]]>Nitesh Verma2010-07-28T19:20:23-00:00Re: Missing requirement org.eclipse.cor.runtime
https://www.eclipse.org/forums/index.php/mv/msg/172851/550038/#msg_550038
Apparently that plugin declares that it just won't work with version 3.5
or higher of the core runtime so you shouldn't expect to install it in
Helios or Galileo.
Nitesh Verma wrote:
> not be found.
> can anyone help
> Thanks in advance,
> Nitesh]]>Ed Merks2010-07-28T20:11:06-00:00Re: Missing requirement org.eclipse.cor.runtime
https://www.eclipse.org/forums/index.php/mv/msg/172851/550044/#msg_550044
In the plugin website it is given that the requirement is eclipse 3.5
how can i have org.eclipse.core.runtime in my eclipse.
and if it is present how can i check..]]>Nitesh Verma2010-07-28T20:58:05-00:00Re: Missing requirement org.eclipse.cor.runtime
https://www.eclipse.org/forums/index.php/mv/msg/172851/550064/#msg_550064
The message requires 'org.eclipse.core.runtime [3.4.0,3.5.0)' tells me
that the inclusive lower bound in 3.4.0 and the exclusive upper bound is
3.5.0 so that sounds like the Ganymede version of Eclipse, i.e., the 3.4
release. So to me, whatever you're installing will only install into
Ganymede.
Use Help->About Eclipse SDK->Installation Details->Plug-ins to see what
plugin versions are in your installation.
Nitesh Verma wrote:
> Thanks for your quick reply.
> http://na.blackberry.com/eng/developers/browserdev/eclipsepl ugin.jsp
> and if it is present how can i check..]]>Ed Merks2010-07-29T02:03:20-00:00Re: Missing requirement org.eclipse.cor.runtime
https://www.eclipse.org/forums/index.php/mv/msg/172851/550362/#msg_550362
Its working on Ganymede version of Eclipse.]]>Nitesh Verma2010-07-30T06:18:40-00:00
