Eclipse Community ForumsCompile UML2TOOLS
https://www.eclipse.org/forums/index.php/mv/msg/172573/549116/#msg_549116
I need help...
Can help me?
Thanks...]]>Andres 2010-07-24T18:41:48-00:00Re: Compile UML2TOOLS
https://www.eclipse.org/forums/index.php/mv/msg/172573/549344/#msg_549344
As I said in the previous POST, i dowloaded, all the dependencies of the project, but always the ide show me that it needs more jars to compile.
I tried export all the dependencies from update manager too, and import the jars from eclipse plugin folder, but it didnt work neither.
bye]]>Andres 2010-07-26T13:44:03-00:00Re: Compile UML2TOOLS
https://www.eclipse.org/forums/index.php/mv/msg/172573/551715/#msg_551715
See How_To_Regenerate_Diagrams_(Alternative) (Wiki article). Hope this helps. Else reply to this post and I'll try to help as best as I can
Christian Waniek]]>Christian Waniek2010-08-09T10:16:13-00:00Re: Compile UML2TOOLS
https://www.eclipse.org/forums/index.php/mv/msg/172573/551850/#msg_551850
Last week, i can compiled too, but now i have problems to regenerate diagrams...
I share us too a short recipe about the steps that i followed to compile the project, and some problems that i had.
1-Download form eclipse cvs, uml2tools(the head version of
2009/06/19).
2-In eclipse galileo, uses update manager, to download form galileo update site these follows plugins:
(EMF - Eclipse Modeling Framework runtime and Tools ,emf, EMF SDK , Graphical Editing Framework GEF,GEF SDK , Graphical Modeling Framework Runtime , Graphical Modeling Framework SDK ,
3-open the dowload project into eclipse(uml2tools), and add in builddependences of the projects, all plugin folder of eclipse galileo,and for exaple from findjar.com load this jars:
-class ActivityPartition_StructuredActivityNode_StructuredActivityN odeContentPaneCompartmentEditPart extends ShapeCompartmentEditPart
in org.eclipse.uml2.diagram.activity.edit.parts package.
-class public class ActivityPartition_StructuredActivityNode_StructuredActivityN odeContentPaneCompartmentCanonicalEditPolicy extends CanonicalEditPolicy
in package org.eclipse.uml2.diagram.activity.edit.policies
-class public class ActivityPartition_StructuredActivityNode_StructuredActivityN odeContentPaneCompartmentItemSemanticEditPolicy
in package org.eclipse.uml2.diagram.activity.edit.policies;.
5-Download from source code of project uml2, fodler org.eclipse.uml2.uml/models
and from gmp project, folders org.eclipse.gmf.gmfpraph/models and org.eclipse.gmf.runtime.notaion/models.
6-Make plugin folder in uml2tools source,
and stores the packages/folders download in step 5(org.eclipse.uml2.uml/models,org.eclipse.gmf.gmfpraph/model s and org.eclipse.gmf.runtime.notaion/models).
]]>Andres 2010-08-09T18:20:27-00:00Re: Compile UML2TOOLS
https://www.eclipse.org/forums/index.php/mv/msg/172573/551972/#msg_551972
1- ok
2- I downloaded and installed the dependencies without the update manager, but this also should work
3- usually youn shouldn't have need for services like findjar.com, or anything like this. If there are missing jars you are missing some plugins. Or your target platform doesn't offer these plugins. maybe you should checkk this.
4- do you have an operating system which limits the length of pathes? if so the missing files couldn't checked out because storing them on your hard disk failed due to too long filenames. I checked out to c:\MDT\, this works very wel
5- I don't know why you need this?
6- dto.
To build your own U2T release (a quick way, without using PDE-Build):
- Create an Update Site project
- Create a category and add the org.eclipse.uml2-diagram feature
- Click build
- Wait some minutes
- you'll find all u2t jars in the subfolder plugins of the update site projects. So you can install them manually (copy & paste) or you can use the update manager
Christian Waniek]]>Christian Waniek2010-08-10T11:17:50-00:00Re: Compile UML2TOOLS
https://www.eclipse.org/forums/index.php/mv/msg/172573/553556/#msg_553556
May be we still have problems with versions, we are currently using:
can you help us again?]]>Andres 2010-08-18T01:52:33-00:00Re: Compile UML2TOOLS
https://www.eclipse.org/forums/index.php/mv/msg/172573/554064/#msg_554064
we are not having problems with the version of emf as we state in last post, but we still have problems regenerating diagrams.
In particular the problem is when we select the option of 'create generator model ' (right click in any file .gmfmap). We select the option ignore validation problems, but at the last step, when the wizzard ask to specify transformation options we tried all the combinations posibles, but always throw the error message:
org/eclipse/gmf/mappings/ExpressionLabelMapping
We really need to make the regeneration work in order to start our university proyect.
It would be very helpfull if you could give us any suggestion or something to try... because we are stucked.
