Eclipse Community ForumsHow can I add all PHP functions to templates?
https://www.eclipse.org/forums/index.php/mv/msg/171010/543642/#msg_543642
or how can I have the PHP functions (strstr, str_replace, array_search, etc) show up in the autocomplete popup?
Thanks in advanced,
Jorge]]>Jorge Garifuna2010-06-30T07:24:09-00:00Re: How can I add all PHP functions to templates?
https://www.eclipse.org/forums/index.php/mv/msg/171010/544422/#msg_544422
Did you upgrade from a previous version? Which version are you using / did you use earlier?]]>Missing name Mising name2010-07-02T15:45:03-00:00Re: How can I add all PHP functions to templates?
https://www.eclipse.org/forums/index.php/mv/msg/171010/544506/#msg_544506
The only auto-complete words I get by pressing ctrl+space are those located at preferences->PHP->editor->template.
There are many PHP functions not included in the default listing, including among others; strstr(), str_replace(), array_search().
Do you have instructions on how to activate auto-complete for PHP functions not included in preferences->PHP->editor->templat ?]]>Jorge Garifuna2010-07-03T02:03:32-00:00Re: How can I add all PHP functions to templates?
https://www.eclipse.org/forums/index.php/mv/msg/171010/545936/#msg_545936
Jorge Garifuna2010-07-09T16:14:41-00:00Re: How can I add all PHP functions to templates?
https://www.eclipse.org/forums/index.php/mv/msg/171010/633696/#msg_633696
Jorge Garifuna2010-10-18T23:14:24-00:00Re: How can I add all PHP functions to templates?
https://www.eclipse.org/forums/index.php/mv/msg/171010/633702/#msg_633702
Code Completion doesn't find many PHP functions 2.1 does
but not "including among others; strstr(), str_replace(), array_search()".
Did you try reinstalling?
Or try installing newer version, 2.2.1(Helios SR1, Build id: 20100917-0705).
]]>Toshihiro Izumi2010-10-19T01:11:33-00:00Re: How can I add all PHP functions to templates?
https://www.eclipse.org/forums/index.php/mv/msg/171010/633960/#msg_633960
No real name2010-10-20T04:11:36-00:00Re: How can I add all PHP functions to templates?
https://www.eclipse.org/forums/index.php/mv/msg/171010/642617/#msg_642617
]]>Max Diaz2010-12-02T02:01:48-00:00
