Eclipse Community ForumsDebugging stopped working
https://www.eclipse.org/forums/index.php/mv/msg/169985/540008/#msg_540008
today debugging has stopped working for me.
It does stop at the first line or breakpoint.
Pressing "Step Into" or "Step Over" will skip any other breakpoints after that, not terminating, and the page will be white with a status of "Ready".
Terminating will still work as before, opening a new tab telling me the debug session has ended.
Pressing "Resume" may or may not, after a significant delay, return to the same breakpoint (never another).
It worked fine before, and I did not change any configuration.
Any ideas what to try?]]>Thomas2010-06-14T15:03:32-00:00Re: Debugging stopped working
https://www.eclipse.org/forums/index.php/mv/msg/169985/540012/#msg_540012
Thomas2010-06-14T15:06:15-00:00Re: Debugging stopped working
https://www.eclipse.org/forums/index.php/mv/msg/169985/541600/#msg_541600
Are there any logs or anything like that?
apache logs don't show anything out of the ordinary.]]>Thomas2010-06-21T18:00:21-00:00Re: Debugging stopped working
https://www.eclipse.org/forums/index.php/mv/msg/169985/541609/#msg_541609
but it's a real showstopper... if no one has any ideas i'm gonna try to reinstall and get back here if it doesn't work]]>Thomas2010-06-21T18:40:08-00:00Re: Debugging stopped working
https://www.eclipse.org/forums/index.php/mv/msg/169985/541678/#msg_541678
Originally posted by: dkel50.hotremovemail.com
you may also want to go to www.xdebug.org to find out how to ask
questions on the mailing list.
Dave Kelsey
On 21/06/2010 19:40, thomas.robertz@googlemail.com wrote:
> I can still refresh then the breakpoint gets hit again... inspecting
> variables still works
> reinstall and get back here if it doesn't work]]>2010-06-22T06:53:39-00:00
