Eclipse Community ForumsRe: Eugenia: Nodes with images instead of shapes
https://www.eclipse.org/forums/index.php/mv/msg/162666/514580/#msg_514580
This was not meant to be interpreted as a link - although it looks
suspiciously like one. What I meant is that all the projects of this
example are in the SVN under
and their names follow the
org.eclipse.epsilon.eugenia.examples.friends.* pattern.
Dimitris
Dimitris Kolovos wrote:
> Hi Zuryman,
> You can find the complete source code of this example in the SVN
> ( http://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.epsi lon/trunk/examples/org.eclipse.epsilon.eugenia.examples.frie nds.*
> projects)
> Cheers,
> Dimitris
> Zuryman wrote:
>> Hi, dimitri...
>> i've trying to create nodes with images instead of shapes..
>> but i dont know where can I find this import...
>> can u help me?
>> ¿¿¿import
>> org.eclipse.epsilon.eugenia.examples.friends.figures.activat
>> or.PluginActivator; ????
>>]]>Dimitrios Kolovos2010-02-15T15:12:07-00:00Eugenia: Nodes with images instead of shapes
https://www.eclipse.org/forums/index.php/mv/msg/162666/514542/#msg_514542
Zuryman wrote:
> Hi, dimitri...
> can u help me?
> ¿¿¿import org.eclipse.epsilon.eugenia.examples.friends.figures.activat
>]]>Dimitrios Kolovos2010-02-15T19:29:17-00:00Re: Eugenia: Nodes with images instead of shapes
https://www.eclipse.org/forums/index.php/mv/msg/162666/586216/#msg_586216
projects)
Dimitris
Zuryman wrote:
> Hi, dimitri...
> can u help me?
https://www.eclipse.org/forums/index.php/mv/msg/162666/514576/#msg_514576
this link doesn't exist anymore..
can you give me another link?
it doesn't work....]]>Zuryman 2010-02-15T19:46:10-00:00Re: Eugenia: Nodes with images instead of shapes
https://www.eclipse.org/forums/index.php/mv/msg/162666/586240/#msg_586240
it doesn't work....]]>Zuryman 2010-02-15T19:46:12-00:00Re: Eugenia: Nodes with images instead of shapes
https://www.eclipse.org/forums/index.php/mv/msg/162666/586255/#msg_586255
Dimitris
> Hi Zuryman,
> projects)
> Cheers,
> Dimitris
> Zuryman wrote:
>> Hi, dimitri...
>> can u help me?
>> ¿¿¿import
>>]]>Dimitrios Kolovos2010-02-15T19:50:04-00:00Re: Eugenia: Nodes with images instead of shapes
https://www.eclipse.org/forums/index.php/mv/msg/162666/514581/#msg_514581
Tanks again....
now ...I can did it... well..
]]>Zuryman 2010-02-15T20:17:04-00:00Re: Eugenia: Nodes with images instead of shapes
https://www.eclipse.org/forums/index.php/mv/msg/162666/586271/#msg_586271
Tanks again....
now ...I can did it... well..]]>Zuryman 2010-02-15T20:17:06-00:00
