Eclipse Community ForumsPDE Build not working in command line
https://www.eclipse.org/forums/index.php/mv/msg/160521/507239/#msg_507239
http://www.vogella.de/articles/EclipsePDEBuild/article.html. The build works fine. When i run the same using java -jar <eclipseInstall>/plugins/org.eclipse.equinox.launcher_<version >.jar -application org.eclipse.ant.core.antRunner -buildfile <<eclipseInstall>/plugins/org.eclipse.pde.build_<version>/scripts/productBuild/productBuild.xml > -Dbuilder=<path to the build configuration folder>
in command line it doesn't work. I'm planning to integrate my app with cruisecontrol for continous integration, is there any way to run the build in cruisecontrol or in commandline]]>Shiva Selvadurai2010-01-12T10:20:01-00:00
