@Entity @Table(name="users") public class User { @Id @Column(name="username") private String username; @Column(name="password") private String password; @OneToMany(fetch=FetchType.LAZY, mappedBy="fromUser") @OrderColumn(name="mail_id desc") private List<UserMail> sentMails; @OneToMany(fetch=FetchType.LAZY, mappedBy="toUser") @OrderColumn(name="mail_id desc") private List<UserMail> receivedMails; public int hashCode() { final int prime = 31; int result = 1; result = prime * result + ((username == null) ? 0 : username.hashCode()); return result; } public boolean equals(Object obj) { if (this == obj) return true; if (obj == null) return false; if (!(obj instanceof User)) return false; User other = (User) obj; if (username == null) { if (other.username != null) return false; } else if (!username.equals(other.username)) return false; return true; } //generated getters and setters public String getUsername() { return username; } public void setUsername(String username) { this.username = username; } public String getPassword() { return password; } public void setPassword(String password) { this.password = password; } public List<UserMail> getSentMails() { return sentMails; } public void setSentMails(List<UserMail> sentMails) { this.sentMails = sentMails; } public List<UserMail> getReceivedMails() { return receivedMails; } public void setReceivedMails(List<UserMail> receivedMails) { this.receivedMails = receivedMails; } }
@Entity @Table(name="mails") public class Mail { @Id @Column(name="mail_id") private long id; @Column(name="title") private String title; @Column(name="content") private String content; @OneToMany(fetch=FetchType.LAZY, mappedBy="mail") @OrderColumn(name="to_username asc") private List<UserMail> shipments; //generated getters and setters public long getId() { return id; } public void setId(long id) { this.id = id; } public String getTitle() { return title; } public void setTitle(String title) { this.title = title; } public String getContent() { return content; } public void setContent(String content) { this.content = content; } public List<UserMail> getShipments() { return shipments; } public void setShipments(List<UserMail> shipments) { this.shipments = shipments; } }
@Entity @IdClass(UserMail.Pk.class) @Table(name="user_mails") public class UserMail { public static class Pk implements Serializable { private static final long serialVersionUID = 7883097744987560068L; private long mail; private String fromUser; private String toUser; @Override public int hashCode() { final int prime = 31; int result = 1; result = prime * result + ((fromUser == null) ? 0 : fromUser.hashCode()); result = prime * result + (int) (mail ^ (mail >>> 32)); result = prime * result + ((toUser == null) ? 0 : toUser.hashCode()); return result; } @Override public boolean equals(Object obj) { if (this == obj) return true; if (obj == null) return false; if (!(obj instanceof Pk)) return false; Pk other = (Pk) obj; if (fromUser == null) { if (other.fromUser != null) return false; } else if (!fromUser.equals(other.fromUser)) return false; if (mail != other.mail) return false; if (toUser == null) { if (other.toUser != null) return false; } else if (!toUser.equals(other.toUser)) return false; return true; } public long getMail() { return mail; } public void setMail(long mail) { this.mail = mail; } public String getFromUser() { return fromUser; } public void setFromUser(String fromUser) { this.fromUser = fromUser; } public String getToUser() { return toUser; } public void setToUser(String toUser) { this.toUser = toUser; } }; @Id @ManyToOne @JoinColumn(name="mail_id", referencedColumnName="mail_id") private Mail mail; @Id @ManyToOne @JoinColumn(name="from_username", referencedColumnName="username") private User fromUser; @Id @ManyToOne @JoinColumn(name="to_username", referencedColumnName="username") private User toUser; @Column(name="status") private int status; public Mail getMail() { return mail; } public void setMail(Mail mail) { this.mail = mail; } public User getFromUser() { return fromUser; } public void setFromUser(User fromUser) { this.fromUser = fromUser; } public User getToUser() { return toUser; } public void setToUser(User toUser) { this.toUser = toUser; } public int getStatus() { return status; } public void setStatus(int status) { this.status = status; } }
Exception [EclipseLink-148] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.DescriptorException Exception Description: The container policy [IndirectListContainerPolicy(class org.eclipse.persistence.indirection.IndirectList)] is not compatible with transparent indirection. Mapping: org.eclipse.persistence.mappings.OneToManyMapping[sentMails] Descriptor: RelationalDescriptor(User --> [DatabaseTable(users)]) Exception [EclipseLink-148] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.DescriptorException Exception Description: The container policy [IndirectListContainerPolicy(class org.eclipse.persistence.indirection.IndirectList)] is not compatible with transparent indirection. Mapping: org.eclipse.persistence.mappings.OneToManyMapping[receivedMails] Descriptor: RelationalDescriptor(User --> [DatabaseTable(users)]) Local Exception Stack: Exception [EclipseLink-148] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.DescriptorException Exception Description: The container policy [IndirectListContainerPolicy(class org.eclipse.persistence.indirection.IndirectList)] is not compatible with transparent indirection. Mapping: org.eclipse.persistence.mappings.OneToManyMapping[sentMails] Descriptor: RelationalDescriptor(User --> [DatabaseTable(users)]) at org.eclipse.persistence.exceptions.DescriptorException.invalidContainerPolicyWithTransparentIndirection(DescriptorException.java:772) at org.eclipse.persistence.internal.indirection.TransparentIndirectionPolicy.validateContainerPolicy(TransparentIndirectionPolicy.java:521) at org.eclipse.persistence.mappings.CollectionMapping.validateBeforeInitialization(CollectionMapping.java:2184) at org.eclipse.persistence.descriptors.ClassDescriptor.validateBeforeInitialization(ClassDescriptor.java:5260) at org.eclipse.persistence.descriptors.ClassDescriptor.preInitialize(ClassDescriptor.java:3323) at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:429) at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:406) at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:671) at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.login(DatabaseSessionImpl.java:633) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:230) at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:368) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:151) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:207) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:195) at org.springframework.orm.jpa.JpaTransactionManager.createEntityManagerForTransaction(JpaTransactionManager.java:400) at org.springframework.orm.jpa.JpaTransactionManager.doBegin(JpaTransactionManager.java:321) at org.springframework.transaction.support.AbstractPlatformTransactionManager.getTransaction(AbstractPlatformTransactionManager.java:371) at org.springframework.transaction.interceptor.TransactionAspectSupport.createTransactionIfNecessary(TransactionAspectSupport.java:336) at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:102) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202) at $Proxy12.authenticate(Unknown Source) at test.UserServiceTest.testAuthenticate(UserServiceTest.java:26) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44) at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15) at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41) at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20) at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28) at org.springframework.test.context.junit4.statements.RunBeforeTestMethodCallbacks.evaluate(RunBeforeTestMethodCallbacks.java:74) at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31) at org.springframework.test.context.junit4.statements.RunAfterTestMethodCallbacks.evaluate(RunAfterTestMethodCallbacks.java:82) at org.springframework.test.context.junit4.statements.SpringRepeat.evaluate(SpringRepeat.java:72) at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.runChild(SpringJUnit4ClassRunner.java:240) at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:46) at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:180) at org.junit.runners.ParentRunner.access$000(ParentRunner.java:41) at org.junit.runners.ParentRunner$1.evaluate(ParentRunner.java:173) at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28) at org.springframework.test.context.junit4.statements.RunBeforeTestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java:61) at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31) at org.springframework.test.context.junit4.statements.RunAfterTestClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:70) at org.junit.runners.ParentRunner.run(ParentRunner.java:220) at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.run(SpringJUnit4ClassRunner.java:180) at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:46) at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197) Local Exception Stack: Exception [EclipseLink-148] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.DescriptorException Exception Description: The container policy [IndirectListContainerPolicy(class org.eclipse.persistence.indirection.IndirectList)] is not compatible with transparent indirection. Mapping: org.eclipse.persistence.mappings.OneToManyMapping[receivedMails] Descriptor: RelationalDescriptor(User --> [DatabaseTable(users)]) at org.eclipse.persistence.exceptions.DescriptorException.invalidContainerPolicyWithTransparentIndirection(DescriptorException.java:772) at org.eclipse.persistence.internal.indirection.TransparentIndirectionPolicy.validateContainerPolicy(TransparentIndirectionPolicy.java:521) at org.eclipse.persistence.mappings.CollectionMapping.validateBeforeInitialization(CollectionMapping.java:2184) at org.eclipse.persistence.descriptors.ClassDescriptor.validateBeforeInitialization(ClassDescriptor.java:5260) at org.eclipse.persistence.descriptors.ClassDescriptor.preInitialize(ClassDescriptor.java:3323) at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:429) at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:406) at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:671) at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.login(DatabaseSessionImpl.java:633) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:230) at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:368) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:151) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:207) at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:195) at org.springframework.orm.jpa.JpaTransactionManager.createEntityManagerForTransaction(JpaTransactionManager.java:400) at org.springframework.orm.jpa.JpaTransactionManager.doBegin(JpaTransactionManager.java:321) at org.springframework.transaction.support.AbstractPlatformTransactionManager.getTransaction(AbstractPlatformTransactionManager.java:371) at org.springframework.transaction.interceptor.TransactionAspectSupport.createTransactionIfNecessary(TransactionAspectSupport.java:336) at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:102) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202) at $Proxy12.authenticate(Unknown Source) at test.UserServiceTest.testAuthenticate(UserServiceTest.java:26) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44) at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15) at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41) at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20) at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28) at org.springframework.test.context.junit4.statements.RunBeforeTestMethodCallbacks.evaluate(RunBeforeTestMethodCallbacks.java:74) at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31) at org.springframework.test.context.junit4.statements.RunAfterTestMethodCallbacks.evaluate(RunAfterTestMethodCallbacks.java:82) at org.springframework.test.context.junit4.statements.SpringRepeat.evaluate(SpringRepeat.java:72) at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.runChild(SpringJUnit4ClassRunner.java:240) at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:46) at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:180) at org.junit.runners.ParentRunner.access$000(ParentRunner.java:41) at org.junit.runners.ParentRunner$1.evaluate(ParentRunner.java:173) at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28) at org.springframework.test.context.junit4.statements.RunBeforeTestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java:61) at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31) at org.springframework.test.context.junit4.statements.RunAfterTestClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:70) at org.junit.runners.ParentRunner.run(ParentRunner.java:220) at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.run(SpringJUnit4ClassRunner.java:180) at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:46) at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Quote: |
private List<UserMail> sentMails; |
Quote: |
@OneToMany(fetch=FetchType.LAZY, mappedBy="fromUser") @OrderBy("mail_id desc") private List<UserMail> sentMails; |
