Eclipse Community ForumsDoes Acceleo work with EMF?
https://www.eclipse.org/forums/index.php/mv/msg/157800/498156/#msg_498156
I am exploring Acceleo to use in a standalone Java/JEE environment.
So far I could see only examples with uml models.
Does Acceleo work with EMF models, XMI input or to that matter any structured input like JET?
And hope it's possible to use Acceleo in JDK 1.4 environment .
Later, still not able to find out good documentation on Acceleo MTL language.
Kindly let me know if there is any resource on the web that helps.
Thank you,
Asha R.]]>Asha Ramegowda2009-11-15T07:44:17-00:00Re: Does Acceleo work with EMF?
https://www.eclipse.org/forums/index.php/mv/msg/157800/498317/#msg_498317
Acceleo works with EMF models. Unfortunately Acceleo is not compliant
with Java 1.4. You need Java 1.5 or higher.
The documentation of Acceleo is in progress it should be released in
M4. You can also have a look at the OMG documentation : http://www.omg.org/spec/MOFM2T/1.0/
regards,
Yvan.
Le dimanche 15 novembre 2009 à 02:44 -0500, Asha R a écrit :
> And hope it's possible to use Acceleo in JDK 1.4 environment :).
> Thank you,
> Asha R.]]>Yvan Lussaud2009-11-16T13:12:23-00:00
