Eclipse Community ForumsException occurred during code generation for the WSDL
https://www.eclipse.org/forums/index.php/mv/msg/157530/496715/#msg_496715
Seem like I got AXIS stuff working but now when I try and create code from WSDL I get:
Exception occurred during code generation for the WSDL : java.lang.NoSuchMethodError: javax.wsdl.Operation.getExtensionAttributes()Ljava/util/Map;
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.jst.ws.axis2.consumption.core.utils.WSDL2JavaGen erator.getAxisService(WSDL2JavaGenerator.java:391)
at org.eclipse.jst.ws.axis2.creation.core.command.Axis2WSDL2Jav aCommand.execute(Axis2WSDL2JavaCommand.java:102)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:419)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:359)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:254)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$6.run(SimpleCommandEngineManager.java:294)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 944)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:264)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:91)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:154)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.getNextPage(SimpleWizardPage.java:136)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:823)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:130)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.lang.NoSuchMethodError: javax.wsdl.Operation.getExtensionAttributes()Ljava/util/Map;
at org.apache.axis2.description.WSDL11ToAxisServiceBuilder.popu lateOperations(WSDL11ToAxisServiceBuilder.java:1296)
at org.apache.axis2.description.WSDL11ToAxisServiceBuilder.popu latePortType(WSDL11ToAxisServiceBuilder.java:591)
at org.apache.axis2.description.WSDL11ToAxisServiceBuilder.popu lateEndpoints(WSDL11ToAxisServiceBuilder.java:468)
at org.apache.axis2.description.WSDL11ToAxisServiceBuilder.popu lateService(WSDL11ToAxisServiceBuilder.java:362)
... 57 more
Any help would be great! ]]>Richard 2009-11-11T06:43:43-00:00Re: Exception occurred during code generation for the WSDL
https://www.eclipse.org/forums/index.php/mv/msg/157530/496725/#msg_496725
This post helped seems like someone needs to update this stuff.
Maybe I'll write something on my blog to save everyone else the headache.]]>Richard 2009-11-11T08:00:18-00:00Re: Exception occurred during code generation for the WSDL
https://www.eclipse.org/forums/index.php/mv/msg/157530/695167/#msg_695167
I am facing the same problem. Link mentioned by you does not seem to be active anymore. So can you please share the solution with me.
Thanks & Regards,
Deepali K.]]>Deepali K.2011-07-11T07:33:05-00:00Re: Exception occurred during code generation for the WSDL
https://www.eclipse.org/forums/index.php/mv/msg/157530/774424/#msg_774424
I'm using:
Stack trace:
Exception occurred while code generation for WSDL null
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.jst.ws.axis2.consumption.core.command.Axis2ClientCodegenCommand.execute(Axis2ClientCodegenCommand.java:183)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.runCommand(CommandFragmentEngine.java:418)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.visitTop(CommandFragmentEngine.java:358)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.moveForwardToNextStop(CommandFragmentEngine.java:253)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager$5.run(SimpleCommandEngineManager.java:252)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:934)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager.runForwardToNextStop(SimpleCommandEngineManager.java:222)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.runForwardToNextStop(WizardPageManager.java:96)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.performFinish(WizardPageManager.java:255)
at org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizard.performFinish(DynamicWizard.java:380)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:742)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:616)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:227)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820)
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.java:182)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:545)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Caused by: java.lang.LinkageError: loader constraint violation: loader (instance of org/apache/tools/ant/AntClassLoader) previously initiated loading for a different type with name "org/w3c/dom/TypeInfo"
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
at org.apache.tools.ant.AntClassLoader.defineClassFromData(AntClassLoader.java:1130)
at org.apache.tools.ant.AntClassLoader.getClassFromStream(AntClassLoader.java:1307)
at org.apache.tools.ant.AntClassLoader.findClassInComponents(AntClassLoader.java:1371)
at org.apache.tools.ant.AntClassLoader.findClass(AntClassLoader.java:1324)
at org.apache.tools.ant.AntClassLoader.loadClass(AntClassLoader.java:1078)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320)
at org.apache.xml.dtm.ref.dom2dtm.DOM2DTM.nextNode(DOM2DTM.java:567)
at org.apache.xml.dtm.ref.DTMDefaultBase._firstch(DTMDefaultBase.java:531)
at org.apache.xml.dtm.ref.DTMDefaultBase.getFirstChild(DTMDefaultBase.java:971)
at org.apache.xpath.axes.ChildIterator.nextNode(ChildIterator.java:89)
at org.apache.xpath.axes.NodeSequence.nextNode(NodeSequence.java:281)
at org.apache.xalan.templates.ElemApplyTemplates.transformSelectedNodes(ElemApplyTemplates.java:278)
at org.apache.xalan.templates.ElemApplyTemplates.execute(ElemApplyTemplates.java:176)
at org.apache.xalan.transformer.TransformerImpl.executeChildTemplates(TransformerImpl.java:2411)
at org.apache.xalan.transformer.TransformerImpl.applyTemplateToNode(TransformerImpl.java:2281)
at org.apache.xalan.transformer.TransformerImpl.transformNode(TransformerImpl.java:1367)
at org.apache.xalan.transformer.TransformerImpl.transform(TransformerImpl.java:709)
at org.apache.xalan.transformer.TransformerImpl.transform(TransformerImpl.java:1284)
at org.apache.xalan.transformer.TransformerImpl.transform(TransformerImpl.java:1262)
at org.apache.axis2.util.XSLTTemplateProcessor.parse(XSLTTemplateProcessor.java:80)
at org.apache.axis2.util.XSLTTemplateProcessor.parse(XSLTTemplateProcessor.java:155)
at org.apache.axis2.util.XSLTTemplateProcessor.parse(XSLTTemplateProcessor.java:117)
at org.apache.axis2.wsdl.codegen.writer.FileWriter.parse(FileWriter.java:175)
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.writeFile(AxisServiceBasedMultiLanguageEmitter.java:2663)
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.writeCallBackHandlers(AxisServiceBasedMultiLanguageEmitter.java:1209)
at org.apache.axis2.wsdl.codegen.emitter.AxisServiceBasedMultiLanguageEmitter.emitStub(AxisServiceBasedMultiLanguageEmitter.java:500)
at org.apache.axis2.wsdl.codegen.CodeGenerationEngine.generate(CodeGenerationEngine.java:282)
... 55 more
(It would be nice if the tutorials (which are still referenced) allowed feedback to permit updating where necessary, and perhaps a troubleshooting section).
-------------]]>Dougal McRae2012-01-03T22:35:45-00:00Re: Exception occurred during code generation for the WSDL
https://www.eclipse.org/forums/index.php/mv/msg/157530/808987/#msg_808987
I'm following the Eclipse tutorial, which demonstrates how to create a client from a bottom-up web service.
Exception occurred during code generation for WSDL : null
java.lang.ArrayIndexOutOfBoundsException: 0
at org.eclipse.jst.ws.axis2.core.utils.Axis2CoreUtils.getSourceFolder(Axis2CoreUtils.java:245)
at org.eclipse.jst.ws.axis2.consumption.core.command.Axis2ClientCodegenCommand.execute(Axis2ClientCodegenCommand.java:138)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.runCommand(CommandFragmentEngine.java:419)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.visitTop(CommandFragmentEngine.java:359)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.moveForwardToNextStop(CommandFragmentEngine.java:254)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager$6.run(SimpleCommandEngineManager.java:294)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager.runForwardToNextStop(SimpleCommandEngineManager.java:264)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.runForwardToNextStop(WizardPageManager.java:91)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.performFinish(WizardPageManager.java:262)
at org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizard.performFinish(DynamicWizard.java:382)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:257)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:277)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
