Eclipse Community ForumsInfocenter Web app , Tomcat
https://www.eclipse.org/forums/index.php/mv/msg/150302/472418/#msg_472418
Originally posted by: wlstrayer.hotmail.com
Trying to set up a WAR running under Tomcat 6.0.16 (Windows) with Eclipse
3.4M5. I can't seem to get the application to pick up the documentation
plugin that I have deployed to the {app}\WEB-INF\eclipse\plugins directory.
When I hit the WAR URL (http://localhost:port/help/index.jsp), the help apps
start but the toc pane is empty on the left. I have cleared Tomcat cache
and restarted the services and still no luck.
Can anyone point me in the correct direction where I might have missed
something? The documentation plugin is working correctly when I run it
with the embedded web server (from the command line).]]>2008-04-01T02:37:45-00:00Re: Infocenter Web app , Tomcat
https://www.eclipse.org/forums/index.php/mv/msg/150302/611088/#msg_611088
Originally posted by: nospam_kowalskilee.gmail.com
Hi Bill,
The Bugzilla entry that tracked development of the WAR version has
comments from people that experienced similar symptoms (toc pane empty).
1. Make sure the docs are *not* in doc.zip form inside a jar'd plug-in.
If the doc plug-in is a jar'd plug-in, then the files should not be
zipped up inside the jar. (Mine worked also if I just had the files
'flat' without jarring the doc plug-in at all).
2. Check to see if your doc plug-in has a dependency on
org.eclipse.core.runtime.compatibility. If you are using an old plug-in,
sometimes it wants org.eclipse.core.runtime.compatibility to work right.
If the doc plug-in has such a dependency, try adding
org.eclipse.core.runtime.compatibility to your plugins directory if it
isn't already there.
3. From file web.xml, remove the following entry if they are in the file:
<init-param>
<param-name>commandline</param-name>
<param-value>-console</param-value>
</init-param>
--Lee Anne
> Eclipse 3.4M5. I can't seem to get the application to pick up the
> documentation plugin that I have deployed to the
> {app}\WEB-INF\eclipse\plugins directory. When I hit the WAR URL
> (http://localhost:port/help/index.jsp), the help apps start but the toc
> pane is empty on the left. I have cleared Tomcat cache and restarted
> with the embedded web server (from the command line).]]>2008-04-01T17:27:33-00:00Re: Infocenter Web app , Tomcat
https://www.eclipse.org/forums/index.php/mv/msg/150302/472420/#msg_472420
Hi Bill,
<init-param>
</init-param>
--Lee Anne
https://www.eclipse.org/forums/index.php/mv/msg/150302/611090/#msg_611090
make a difference whether you open the help system using Internet
Explorer or using Firefox? For some reason I've only ever seen this in
IE and opening the same page in Firefox has caused the books to
magically appear for me.]]>Chris Goldthorpe2008-04-01T17:50:48-00:00Re: Infocenter Web app , Tomcat
https://www.eclipse.org/forums/index.php/mv/msg/150302/472421/#msg_472421
https://www.eclipse.org/forums/index.php/mv/msg/150302/611094/#msg_611094
I get the same results in Internet Explorer 7.0 and in Firefox 2.0. I am
going thru Lee Anne's post to see if any of the suggestions help.
"Chris Goldthorpe" <cgold@us.ibm.com> wrote in message
news:fstslp$697$1@build.eclipse.org...
> I've noticed this myself from time to time but not consistently. Does it
> make a difference whether you open the help system using Internet Explorer
> or using Firefox? For some reason I've only ever seen this in IE and
> opening the same page in Firefox has caused the books to magically appear
> for me.]]>2008-04-01T19:48:58-00:00Re: Infocenter Web app , Tomcat
https://www.eclipse.org/forums/index.php/mv/msg/150302/472423/#msg_472423
https://www.eclipse.org/forums/index.php/mv/msg/150302/611096/#msg_611096
#2 did the trick.. it did have a dependency on
org.eclipse.core.runtime.compatibility. Added that and restarted Tomcat
and everything seems to be working correctly.
Thanks...
"Lee Anne" <nospam_kowalskilee@gmail.com> wrote in message
news:fstr67$kco$1@build.eclipse.org...
> Hi Bill,
> Based on those comments, here are some things to check/try:
> (per reference https://bugs.eclipse.org/bugs/show_bug.cgi?id=201666#c58)
> 1. Make sure the docs are *not* in doc.zip form inside a jar'd plug-in. If
> the doc plug-in is a jar'd plug-in, then the files should not be zipped up
> inside the jar. (Mine worked also if I just had the files 'flat' without
> <init-param>
> </init-param>
> Best regards,
> --Lee Anne
>> directory. When I hit the WAR URL (http://localhost:port/help/index.jsp),
>> the help apps start but the toc pane is empty on the left. I have
>> cleared Tomcat cache and restarted the services and still no luck.
>> with the embedded web server (from the command line).]]>2008-04-01T20:02:26-00:00Re: Infocenter Web app , Tomcat
https://www.eclipse.org/forums/index.php/mv/msg/150302/472424/#msg_472424
Thanks...
> Hi Bill,
> <init-param>
> </init-param>
> Best regards,
> --Lee Anne
https://www.eclipse.org/forums/index.php/mv/msg/150302/614440/#msg_614440
Originally posted by: eclipse.maxant.co.uk
I had some problems with this too, but managed to get around it. I have
written a blog entry / tutorial on how to set it up. Its at:
the only thing i cant get working right now is customisation of the home
page. it works from my RCP app, when help is in workbench mode, but it
doenst work when i drop the plugin into the webapp... anyone got any ideas?
the last line of the eclipse 3.4RC4 help (when you search for "war") says:
Notes: If you look in the config.ini in the help.war file under
directory help/WEB_INF/eclipse/configuration you will notice the
line eclipse.product=org.eclipse.productname. If your product has help
system customizations in a product plugin you can
activate these by changing this line to point to your product plugin.
but under
<tomcat-install>/work/catalina/localhost/_/eclipse/workspace/.metadata/.log
i get the following error message:
!ENTRY org.eclipse.equinox.app 0 0 2008-06-12 19:46:32.937
!MESSAGE Product BookStore could not be found.
here is the entry i put into web-inf/eclipse/configuration/config.ini:
eclipse.product=BookStore
in the plugin.xml, the plugin name (on the overview tab, under general
information) is "BookStore"
so what am i doing wrong?
Ant
"Bill Strayer" <wlstrayer@hotmail.com> schrieb im Newsbeitrag
news:fss761$9s$1@build.eclipse.org...
> the help apps start but the toc pane is empty on the left. I have cleared
> with the embedded web server (from the command line).]]>2008-06-12T21:19:39-00:00Re: Infocenter Web app , Tomcat
https://www.eclipse.org/forums/index.php/mv/msg/150302/473913/#msg_473913
but under
Ant
https://www.eclipse.org/forums/index.php/mv/msg/150302/614441/#msg_614441
Good blog write-up, by the way.
I don't know if this will help you. I offer it as something to try.
I've never seen the config.ini line with only the plug-in name on the
right hand side:
The way that I see the SDK does it, and the way that I do it for my
standalone help, is to have the line of the format:
eclipse.product=org.eclipse.sdk.ide
The "ide" piece on the end is actually identified in an <extension> tag
in the plugin.xml file of the product plug-in. And the "org.eclipse.sdk"
potion is that plug-in's id.
Then, in the plugin.xml file of that product plug-in, it has this
extension (along with other things, naturally):
<plugin>
<extension id="ide" point="org.eclipse.core.runtime.products">
<property name="preferenceCustomization" value="plugin_customization.ini"/>
(that property name="preferenceCustomization" should be all on one line.
My message composer is breaking it oddly here).
See the attribute id="ide"? I think that id and the plug-in's id
together make the connection between the eclipse.product line in
config.ini and this product plug-in.
Then, the property points to the plugin_customization.ini file. In that
file, you can specify the file that you want to be the help home page.
For example, I have this line in my plugin_customization.ini file that I
use for testing an infocenter:
org.eclipse.help.base/help_home=/com.mytest.doc/aboutmytest. htm
In a plug-in named "com.mytest.doc" that has a file named
aboutmytest.htm which is the file that I want for my home page.
Now, I haven't tried this for the WAR version yet. But I set it up this
way for my typical infocenter deployments.
It is something at least to try.
Lee Anne
maxant wrote:
> http://blog.maxant.co.uk/pebble/2008/06/09/1213043100000.htm l
> but under
> Cheers,
> Ant]]>2008-06-12T22:56:55-00:00Re: Infocenter Web app , Tomcat
https://www.eclipse.org/forums/index.php/mv/msg/150302/473914/#msg_473914
right hand side:
<plugin>
Lee Anne
maxant wrote:
> but under
> Cheers,
https://www.eclipse.org/forums/index.php/mv/msg/150302/615254/#msg_615254
hi,
i checked again and youre right, those are the steps i took to get the
customizations to work. the only difference, is that instead of ".ide", i
have ".product". so the value that i put into my config.ini was
BookStore.product, otherwise known as the plugin ID, as defined on the first
page of the .products file! it all makes a little more sense now, and it
even works too.
i will update the two tutorials i wrote on my blog when i get a sec.
thanks!
ant
"Lee Anne" <nospam_kowalskilee@gmail.com> schrieb im Newsbeitrag
news:g2s9cc$u4r$1@build.eclipse.org...
> right hand side:
> The "ide" piece on the end is actually identified in an <extension> tag in
> <plugin>
> See the attribute id="ide"? I think that id and the plug-in's id together
> make the connection between the eclipse.product line in config.ini and
> file, you can specify the file that you want to be the help home page. For
> example, I have this line in my plugin_customization.ini file that I use
> In a plug-in named "com.mytest.doc" that has a file named aboutmytest.htm
> Best regards,
> Lee Anne
> maxant wrote:
>> Hi,
>> ideas? the last line of the eclipse 3.4RC4 help (when you search for
>> "war") says:
>> but under
>> Cheers,
>> Ant
>]]>2008-06-14T16:20:56-00:00Re: Infocenter Web app , Tomcat
https://www.eclipse.org/forums/index.php/mv/msg/150302/474064/#msg_474064
hi,
even works too.
thanks!
ant
> right hand side:
> <plugin>
> Best regards,
> Lee Anne
> maxant wrote:
>> Hi,
>> "war") says:
>> but under
>> Cheers,
>> Ant
