Eclipse Community Forums'Expression is not gettable' error
https://www.eclipse.org/forums/index.php/mv/msg/150222/472157/#msg_472157
Originally posted by: blacksnow666.gmail.com
WTP 1.5, Eclipse 3.2, Calisto bundle,
for some reason or another,
my boolean field values are not gettable
i'm not very sure about this, but i take it
that the "getXXX" for non-boolean and "isXXX" for boolean
but it appears that
the validator is not able to recognize 'isXXX' getters..
the only workaround i can see is to use 'getXXX'
even for boolean values,
anybody has a different method (a.k.a, easier), please let me know]]>2006-07-04T12:24:40-00:00Re: 'Expression is not gettable' error
https://www.eclipse.org/forums/index.php/mv/msg/150222/600844/#msg_600844
This problem has been logged as https://bugs.eclipse.org/bugs/show_bug.cgi?id=149221 You will need to
make your boolean accessors use the "get" form instead of the "is" form to
avoid validation problems until it is fixed.
You can CC yourself on the bug in order to be informed when it is fixed.
If a fix is particularly important to you, please attach a note so that we
can better prioritize the fix.
--Cam
> but it appears that
> anybody has a different method (a.k.a, easier), please let me know]]>Cameron Bateman2006-07-06T03:33:48-00:00Re: 'Expression is not gettable' error
https://www.eclipse.org/forums/index.php/mv/msg/150222/472159/#msg_472159
This problem has been logged as https://bugs.eclipse.org/bugs/show_bug.cgi?id=149221. You will need to
--Cam
> but it appears that
