Eclipse Community ForumsSVN Install fails - dependencies
https://www.eclipse.org/forums/index.php/mv/msg/15015/47927/#msg_47927
I have Ganymede 3.4.1
Mac OSX 10.5.7 (with latest Java version update)
(Ganymede was installed as part of the latest PDT package (PHP))
(tried with Pulsar, which as a matter of fact currently only works with
Android Developer Tools ;-/)
I substituted the Temp path, but this file always gets downloaded wrong!!
Even after deleting it manually the next install fails.
I'll try with a Final distro, but other install issues working in Final also
usually worked with RC4 already.
If it persists, I'll also file a bug.]]>Werner Keil2009-06-28T19:03:36-00:00Re: SVN Install fails - dependencies
https://www.eclipse.org/forums/index.php/mv/msg/15015/48326/#msg_48326
I would recommend you to install Latest release, here are links:
SVN Team Provider: http://download.eclipse.org/technology/subversive/0.7/update -site/
At first install SVN Team Provider and then SVN Connectors.
If you experience any problems with installation, you can install Subversive
from archived update sites.
> (Warning Eclipse newbie, be kind to the ignorant)
> I would like to install SVN
> I reviewed the install instructions at:
> http://www.eclipse.org/subversive/documentation/gettingStart ed/aboutSubversive/install.php
> and end up at:
> http://www.polarion.com/products/svn/subversive.php?src=ecli pseproject
> It seems to indicate under "Ganymede Release" that I should see these two
> entries in my "Updates and Add-ons" module.. I do not.
> I then added the two indicated sites to my list, Refreshed and then
> checked and Install.
> I get the following dependency errors after the install fails..
> Any suggestions as to what I need to install to resolve this..???
> Thanks much....
> John..
> Cannot complete the request. See the details.
> Unsatisfied dependency:
> requiredCapability:
> org.eclipse.equinox.p2.iu/org.maven.ide.eclipse.feature.feat ure.group/[0.9.2,1.0.0)
> requiredCapability:
> org.eclipse.equinox.p2.iu/org.eclipse.team.svn.feature.group /[0.7.2.I20080801-1500,1.0.0)
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> org.eclipse.equinox.p2.iu/com.csc.dip.projectset.feature.fea ture.group/0.0.0
> requiredCapability:
> org.eclipse.equinox.p2.iu/org.eclipse.team.svn.feature.group /[0.7.1.I20080612-1500,1.0.0)
> requiredCapability:
> requiredCapability:
> requiredCapability:
> org.eclipse.equinox.p2.iu/org.polarion.eclipse.team.svn.conn ector.feature.group/0.0.0
> Unsatisfied dependency: requiredCapability:
> org.eclipse.equinox.p2.iu/org.eclipse.ui.workbench/
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> org.eclipse.equinox.p2.iu/org.eclipse.rcp.feature.group/
> requiredCapability:
> org.eclipse.equinox.p2.iu/org.eclipse.platform.feature.group /
> requiredCapability:
> org.eclipse.equinox.p2.iu/org.eclipse.debug.core/
> requiredCapability:
> org.eclipse.equinox.p2.iu/org.eclipse.help.feature.group/
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> [org.polarion.eclipse.team.svn.projectset.feature.group
> 2.0.1.I20080612-1500] requiredCapability:
>]]>Igor Burilo2009-07-03T15:18:38-00:00
