Eclipse Community ForumsLight bug with save as
https://www.eclipse.org/forums/index.php/mv/msg/149750/470733/#msg_470733
playing around a little more with UML2Tools,
I simply clicked on 'Save as'
and I got two simple issues :
1- if I let the original name of the file I get the message :
Save could not be completed. Target file is already open in another
editor.
2- if I enter a new file name, I get the error message :
Cannot open input element:
Reason : Resource xxx does not exist
I believe it is not the excepted behavior of 'Save as' ;)
Has anyone already reported this as a bug ?
Philippe]]>Philippe2007-05-15T13:35:41-00:00Re: Light bug with save as
https://www.eclipse.org/forums/index.php/mv/msg/149750/593494/#msg_593494
The situation you described looks really wrong. Whatever a person does on
"Save as" error dialog appears. This looks like a GMF or GMF Runtime bug.
UML2Tools Diagrams will be regenerated with new GMF in a few days, so it may
be fixed. Let's wait till Friday and after that I will check the situation
and commit a CR if needed. I think it will be needed, as there is no such
report in "GMF New and Noteworthy"
( http://wiki.eclipse.org/index.php/GMF_New_and_Noteworthy#2.0 _M7_.28May_18.2C_2007.29).
Best wishes,
Tatiana.
"Philippe" <philippeweber57@yahoo.fr> wrote in message
news:f2cd1p$ui6$1@build.eclipse.org...
> editor.
> Regards
> Philippe]]>Tatiana Fesenko2007-05-15T21:25:48-00:00Re: Light bug with save as
https://www.eclipse.org/forums/index.php/mv/msg/149750/470739/#msg_470739
Best wishes,
Tatiana.
> editor.
> Regards
https://www.eclipse.org/forums/index.php/mv/msg/149750/470787/#msg_470787
The problem is still relevant with new GMF. I've commited #187772 ""Save
as..." doesn't work" in bugzilla.
Thank you.
Tatiana.
> editor.
> Regards
> Philippe]]>Tatiana Fesenko2007-05-18T10:02:16-00:00Re: Light bug with save as
https://www.eclipse.org/forums/index.php/mv/msg/149750/594078/#msg_594078
Thank you.
Tatiana.
> editor.
> Regards
