Eclipse Community ForumsIs the new Papyrus file format compatible with the old papyrus file format?
https://www.eclipse.org/forums/index.php/mv/msg/149421/469840/#msg_469840
I am thinking about starting to use the old Papyrus (www.papyrusuml.org)
and later switch to the new Papyrus (www.eclipse.org/mdt) once that is
becoming a bit more completed.
My questions is if the data files are compatible, in other words, can I
start to use the old Papyrus to create UML model files, and just open them
in the new Papyrus later on? Or will that not be possible?
Any suggestions are most welcome.
Kind regards,
Johan]]>Johan 2009-04-22T19:14:40-00:00Re: Is the new Papyrus file format compatible with the old papyrus file format?
https://www.eclipse.org/forums/index.php/mv/msg/149421/469841/#msg_469841
In the new papyrus, diagram files will be based on GMF technology. So, we
have planned to develop import tool in order to work on models produced by
the old version of papyrus.
"Johan " <m6b32@hotmail.com> a ]]>Patrick Tessier2009-04-30T09:13:34-00:00Re: Is the new Papyrus file format compatible with the old papyrus file format?
https://www.eclipse.org/forums/index.php/mv/msg/149421/584631/#msg_584631
https://www.eclipse.org/forums/index.php/mv/msg/149421/469845/#msg_469845
Interchange standard will not be supported any more?
Tor
On 2009-04-30 11:13, Patrick Tessier wrote:
> Hi Johan,
> "Johan "<m6b32@hotmail.com> a écrit dans le message de news:
> 17d44da649abc3cf0d8542a54b0da71c$1@www.eclipse.org...
>> Dear all,
>> Kind regards,
>> Johan
>]]>Tor Neple2009-05-06T15:23:37-00:00Re: Is the new Papyrus file format compatible with the old papyrus file format?
https://www.eclipse.org/forums/index.php/mv/msg/149421/584679/#msg_584679
Tor
> Hi Johan,
>> Dear all,
>> Kind regards,
>> Johan
