Eclipse Community ForumsHi,could you pls help me have a look at this question?
https://www.eclipse.org/forums/index.php/mv/msg/148272/466450/#msg_466450
Originally posted by: shikai.cn.ibm.com
From the newsgroup,I saw you post some questions the same as this
before.could you pls share some experiences with me?
thank you very much
Hi,everyone.I got a problem when I implement a RCP app.
This RCP is based on a big xml data.And all the GUI controls will be
created and layout based on this xml data file.
When user open this xml data in app,several tab pages and several panels
will be created and layouted.
However a problem is always raised out when I open this xml data in the
5th time.It means the 1th-4th time I opened is no error.The exception is
"No more handles".However I disposed all the dynamic control each time
when I reopen the new page.I dont know how to catch the problem.
who knows?]]>2006-01-10T16:31:20-00:00Re: Hi,could you pls help me have a look at this question?
https://www.eclipse.org/forums/index.php/mv/msg/148272/466682/#msg_466682
You can use the sleak plugin to track undisposed resources.
See the articles section of eclipse.org for an in-depth introduction to
ui-resources in swt.
> thank you very much
> who knows?
>]]>Yves Harms2006-01-13T10:16:07-00:00
