Eclipse Community ForumsProblem seeing interfaces in Interface Partners property editor
https://www.eclipse.org/forums/index.php/mv/msg/1436/4001/#msg_4001
Originally posted by: jeff.delong.jboss.com
I downloaded the source for the BPEL Designer from CVS following the
Installation instructions and it compiled fine. I launched a new Eclipse
application, created a project for the OrderProcessing example, and can
open its bpel file and wsdl file in the designer. This all works / looks
very nice.
I have created my own simple HelloWorld example. I can edit the wsdl file
in the designer, adding / editing the elements, including the
Extensibility Elements Partner Links. However when I view the bpel file in
the designer I cannot "browse" interfaces in Interface Partners property
editor, nor see a list of interfaces, like I do in the OrderProcessing
example. Also, the icons in the OrderProcessing example wsdl Extensibility
Elements have bpel process icons, whereas the ones I have in my examples
have an "e" icon.
Any directions you could provide on how to make this work is greatly
appreciated.]]>2006-04-14T15:34:53-00:00Re: Problem seeing interfaces in Interface Partners property editor
https://www.eclipse.org/forums/index.php/mv/msg/1436/4004/#msg_4004
The browse dialog functionality has not been implemented yet. Here's the
bug:
> very nice.
> file in the designer, adding / editing the elements, including the
> in the designer I cannot "browse" interfaces in Interface Partners
> property editor, nor see a list of interfaces, like I do in the
> OrderProcessing example. Also, the icons in the OrderProcessing example
> wsdl Extensibility Elements have bpel process icons, whereas the ones I
> have in my examples have an "e" icon.
> appreciated.
>]]>Rodrigo Peretti2006-04-18T13:55:25-00:00Re: Problem seeing interfaces in Interface Partners property editor
https://www.eclipse.org/forums/index.php/mv/msg/1436/4075/#msg_4075
I submitted a bug for the icon issue.
By the way, since the browse feature is not implemented yet, how did get
the interface to show up in the purchaseOrderProcess? Was this added by
hand to the .bpel file?]]>2006-04-18T18:51:13-00:00Re: Problem seeing interfaces in Interface Partners property editor
https://www.eclipse.org/forums/index.php/mv/msg/1436/4277/#msg_4277
imports for them in the .bpel file.
Rodrigo
>]]>Rodrigo Peretti2006-04-21T19:11:16-00:00
