Eclipse Community ForumsHow to update the checked state of a command per window?
https://www.eclipse.org/forums/index.php/mv/msg/110123/336462/#msg_336462
Originally posted by: eclipse-newsgroups.scharf.gr
I have a very hard time finding information
about commands.
Here is a vary simple problem:
- I want to have a command that has a checked (toggle) state
- There is boolean a variable associated with each window
- I want the checked state represent the state of this variable
- when the state changes, the command should change its state
- when handler is called, it should toggle the variable
I have no idea how to do this with commands....
Michael
Michael Scharf
Wind River Systems GmbH http://www.WindRiver.com http://MichaelScharf.blogspot.com/]]>2009-06-15T14:55:37-00:00Re: How to update the checked state of a command per window?
https://www.eclipse.org/forums/index.php/mv/msg/110123/336465/#msg_336465
IElementUpdater. But ...
You would need to use
org.eclipse.ui.commands.ICommandService.refreshElements(Stri ng, Map) to
request that the command update its checked state when the active window
changes, so it can reflect the correct state.
Commands in 3.x run off of a global application context. There is also
only one global command (backed by the currently active handler), so
within one window it becomes impossible to show different states for one
command. Between windows, it might just be possible assuming you are
updating your state to the correctly active window.
Or instead of one handler that needs to manage the state for the
application, programmaticly activate a handler when creating each
separate window using window.getService(IHandlerService.class) to get
the IHandlerService in each case (since that will scope the handler to
that window only).
thank you for the answer! (I'll try this out
tomorrow)
How would I figure all this out without asking the
newsgroup? I feel really stupid and I don't know
how to figure out all the complexity of commands.
Maybe a set of relatively simple examples would help a lot.
It turns out that the actual code that gets executed int
the handler is not the problem. The problem is hooking
the handlers and commands into the application which
includes plugin.xml and window.getService(IHandlerService.class)
all things that are very hard to figure out.
Michael
> Your handler would be updating the state after implementing
> that window only).
> PW
Michael Scharf
Wind River Systems GmbH http://www.WindRiver.com http://MichaelScharf.blogspot.com/]]>2009-06-15T19:58:52-00:00Re: How to update the checked state of a command per window?
https://www.eclipse.org/forums/index.php/mv/msg/110123/336475/#msg_336475
It's not you :-)
Right now, the resources on commands are the wiki included in my sig and
the (updated with Galileo out soon) stuff in the Help>Help
Contents>Platform Plug-in Developer Guide. But they're pretty slim.
I had hoped to create some more extensive docs on this along with
examples for each thing that people would like to do (for example,
checked state commands can now save their state so they reflect it
correctly on the next startup without activating their plugin). But
while 3.5 is ramping down, the work we need to put into e4 to be ready
at the end of July is consuming all of our time.
