Eclipse Community Forumsspecifying location of a new group to be added the file menu
https://www.eclipse.org/forums/index.php/mv/msg/109996/336093/#msg_336093
I have been trying to add a new menu item under the file menu which will
also be its own group, that is, it will be surrounded by separators. I
would like to put this new group after the fileStart group (that is, after
the separator following the "New" and "Open File.."). I have successfully
created the new menu item with the seperators but by default this new item
is placed between the "Export.." and "Properties" menu items. I have been
reading the help file but have not yet found a way to place it where I
want it to go. Has anyone tried to do this before? If so, will you please
give me some advice?]]>No real name2009-05-21T00:43:13-00:00Re: specifying location of a new group to be added the file menu
https://www.eclipse.org/forums/index.php/mv/msg/109996/336102/#msg_336102
org.eclipse.ui.internal.ide.WorkbenchActionBuilder.createFil eMenu() to
see the structure that is created for the File menu. What are you doing
to add these? In org.eclipse.ui.menus, the locationURI would be
something like menu:file?after=<id> where <id> is the ID of something
(like a group marker or separator) to begin inserting after.
